jackfelixsmith Posted May 23, 2015 Posted May 23, 2015 The arse has just fell out of my ep 81's 12 valve , and I need to stick in a new engine . Any one ever put in the 16 valve 4e-fe ? If so whats needed and can it be done ? Quote
5e colin Posted May 24, 2015 Posted May 24, 2015 sure can be done but is a lot of work you will need lots of parts if your car is carb Quote
russ78 Posted May 24, 2015 Posted May 24, 2015 might help buddy - http://www.ebay.co.uk/itm/Toyota-Starlet-1993-1000cc-Engine-EP80-Export-/331534868930?pt=LH_DefaultDomain_3&hash=item4d3104a1c2 Quote
jackfelixsmith Posted May 24, 2015 Author Posted May 24, 2015 No its not a carb it was a 1.3 EFI , so that might make it easier ? Quote
morgey Posted May 24, 2015 Posted May 24, 2015 Buy the engine and loom from a ep80 na most will bolt in then Quote
