kevmcc90 Posted May 26, 2015 Posted May 26, 2015 I've just sorted an issue with my gearbox by fitting my old flywheel which has sorted gear selection issues I've been having. Now when at idle there is a loud ticking sound but when you press the clutch this stops? I've fitted uprated engine mounts also incase this could be causing any effect too? Any ideas? Could it be the old flywheel being worn compared to the new clutch? Quote
kevmcc90 Posted May 26, 2015 Author Posted May 26, 2015 (edited) http://vid1052.photobucket.com/albums/s460/kevmcc1990/MOV_0039.mp4 here is a video if this helps? Edited May 26, 2015 by kevmcc90 Quote
kevmcc90 Posted May 27, 2015 Author Posted May 27, 2015 On a long drive there, it's jumping out of fourth randomly. And when going down the gears it judders a lot when coming off clutch? Quote
H_D Posted May 27, 2015 Posted May 27, 2015 If its popping out of gear then there is an issue with the gearbox. Quote
ROTABOOST Posted May 27, 2015 Posted May 27, 2015 As above mate if it's popping out of gear then the box has a fault Quote
kevmcc90 Posted May 27, 2015 Author Posted May 27, 2015 Just it wasn't doing this before I put old flywheel back on Quote
