daveEP Posted June 7, 2015 Posted June 7, 2015 Can anyone tell me how to remove the piston from the rod tryed heating the rod and supposedly the small end bearing should just slide out??? Is this right? Mines is solid. Quote
turbominicooper Posted June 7, 2015 Posted June 7, 2015 is the gudgeon pins not held in by circlips? remove the circlips and slide pin out, disconnect rod from piston no?? Quote
5e colin Posted June 7, 2015 Posted June 7, 2015 need to press them out with a press ours dont have clips in them ryan Quote
turbominicooper Posted June 7, 2015 Posted June 7, 2015 ah right i didnt know, havent got that far in stripping mine yet ;) Quote
daveEP Posted June 7, 2015 Author Posted June 7, 2015 Klkl cheers guys. So the glanza have the circlips and pin and the gt has to be pressed? Quote
turbominicooper Posted June 7, 2015 Posted June 7, 2015 i think from what colins said they are all press type Quote
daveEP Posted June 7, 2015 Author Posted June 7, 2015 Kl that's what a was really looking to find out if the had to be pressed. 👍 Quote
daveEP Posted June 7, 2015 Author Posted June 7, 2015 Cheers for the help and clearing that up too. 👍 Quote
patman Posted June 7, 2015 Posted June 7, 2015 When mine got rebuilt not so long ago had to take it to engineers place to have them pressed out Quote
