Duduglanza Posted June 9, 2015 Posted June 9, 2015 What should i do if air is trapped in the abs modulator since i left the master to empty itself while doing new fluid?? Quote
Duduglanza Posted June 9, 2015 Author Posted June 9, 2015 I was thinking about it.. but right now i prefer to leave it as it is.. Quote
Broony Posted June 9, 2015 Posted June 9, 2015 only option is bleed the system up take her for a spin and activate abs then re bleed system Quote
Duduglanza Posted June 10, 2015 Author Posted June 10, 2015 Is there a way i can trigger the abs pump alone? Quote
Duduglanza Posted June 12, 2015 Author Posted June 12, 2015 Just found it was an abs problem. One solenoid was stuck close. Few blows and all fine now Quote
