Think i asked this before but not sure, so i'm guessing the 4EFTE mani will just bolt onto the 4EFE and it's just a case of blocking some bits off and messing with the sensors? just need a bit or re assurance before i go and fit it lol
Yeah, it's a bolt on. The TPS and IACV are the sensors that don't match up.
When I had one on, I managed to combine an N/A TPS with the mounting plate from an FTE one and file the shaft down to be the right shape, but the IACV was a problem I couldn't get round, losing the idle up systems knocked a huge amount of fuel mileage off as the ecu thinks the engines cold all the time so overfuels constantly.
Also worth bearing in mind is it'll add a pretty hefty flat spot to your torque up to 3-3.5k. After that, it's fucking awesome though :)
