Just sourcing a set of these and wanted a bit more info...
Does anyone have a part number for say SARD/HKS etc injector for the EP? as in direct fitment? And what other model car injector will fit, like the JZA80 and FC3S/FD3S? has to be 550s :lol:
Cheers chaps!
only UK Spec supras were 550cc's mate, and i think they fit...
(if you are talking about running stock supra ones that is?)
Will work out alot cheaper than buying sard ones etc...
on another note did you get that PM i sent you ;) :)
the FC ones fit perfectly. you just need to feck about with the plugs.
they are the only hi imp injectors that fit, but youre running standalone. so it doenst matter :)
i have the cruise ones, which are basically sard ones. ill have a look to see if i have the numbers
Cheers guys,
Rick if you can get those numbers that'd be good! So Supra UK Turbo injectors will fit no problems? :)
Im hoping to get new ones by the way, the one on fleebay were used?
Mark
