Hi knowledgeable guys I'm having problems with the car is running rough on idle did compression test and it came out 1#170psi 2#100psi 3#100psi 4#170psi no smoke out of the breather but did have blown exhaust manifold did not notice not mixing oil and water power is down but did notice everytime when switching the car I hear water ghussing some were in the car please help thanks
those compression test figures do not sound good - probably head gasket failure.
The water noise it probably a dodgy matrix or water pump
Thanks for getting back and how easy to do the head do I have to skim it even thou it did not overheat because the head is non interference I'll get the water pump done and belt at the same time
Always get the head checked by an engineer and let them decide if it needs to be skimmed/resurfaced.
Change the water pump and get a new timing belt kit too.
