starlybruiser Posted February 17, 2008 Posted February 17, 2008 Hi Guys, just a wee question for you, i have noticed a small noise coming from the front O/S wheel area, and its getting annoying, its when i turn left i can hear a plastic scraping noise like the inner arch plastics are loose and they shift to one side when i tun and shift back when i straighten back up?? it only seems to do it every so often and more so when im goin fast?? any ideas if theres anything that can work loose in that area?? i have checked the inner plastics and they all seem firmly in place, any help is greatly appreciated, cheers starlybruiser Quote
starletno1fan Posted February 17, 2008 Posted February 17, 2008 might sound stupid but check your wheel bolts are tightly on! Quote
Glanza_Ragger Posted February 17, 2008 Posted February 17, 2008 Take the wheel off, check all the inner arch plastics are firmly clipped in.Check the wheel nuts, check the brakes, damper, everything.Failing that, jack that side wheel up and see if it wobbles.Check the bearing. Quote
vineygt Posted February 17, 2008 Posted February 17, 2008 how much is the car lowered by and wheel size? could just be the wheel scrubbing every now and again? Quote
