FrozenJakalope Posted July 15, 2015 Share Posted July 15, 2015 I bought an alarm/immobiliser kit. The immobiliser is a relay that can kill a single wire, I'm wondering where the best place to put it is. Current thinking is fuel pump, is this a good call? If so, what's the best way to access the wiring for it from under the dash? Quote Link to post Share on other sites
5e colin Posted July 15, 2015 Share Posted July 15, 2015 best not to mention where you going to put it on the net but if you are clever you can cut of any system of your liking in the car make sure no1 can find it i would not do fuelpump because every1 does pump so easy to run wire to it pm me i have a good tip for you Quote Link to post Share on other sites
