patman Posted July 20, 2015 Share Posted July 20, 2015 Hello gang just need alittle advice please, Was under the bonnet today changing air filter and as you do while your there checking hoses plugs and sensors, I put my hand on the icv sensor only for one of the wires to come out (due to age must be being brittle as redone other sensor wires that pop out the hole). Obviously I will get it redone ASAP and connect the wire back up, but my question is will the car be ok to run like that for the next few days, have been out in it since and car just runs normal like it should not even high idle, thanks pat Quote Link to post Share on other sites
Ollieh17 Posted July 20, 2015 Share Posted July 20, 2015 Removed my idle control valve and blanked it off. Car ran alot better Quote Link to post Share on other sites
patman Posted July 20, 2015 Author Share Posted July 20, 2015 Hey Ollie yeah heard people doing this, what did you do with the sensor? (Just tuck it away) plus the hole in the side of the inlet? And the pipe bit what goes into the bottom of the icv? Quote Link to post Share on other sites
Ollieh17 Posted July 20, 2015 Share Posted July 20, 2015 Pulled it off, cut wires out, tapped a whole in the inlet and put a bolt in it, then just blanked off the vac hose st the inlet Quote Link to post Share on other sites
patman Posted July 20, 2015 Author Share Posted July 20, 2015 Just like that eh mate if it has benefits might be worth ago thanks mate, by for now need to know if the wires ok not connected Quote Link to post Share on other sites
patman Posted July 21, 2015 Author Share Posted July 21, 2015 Bump anyone know for sure please started car up before work today wasn't idling as high everything seems ok still idling the same when warm idle etc Quote Link to post Share on other sites
Ollieh17 Posted July 21, 2015 Share Posted July 21, 2015 It will be fine mate,no different then it just being removed or unplugged Quote Link to post Share on other sites
patman Posted July 21, 2015 Author Share Posted July 21, 2015 Thanks mate to be fair car doesn't idle so high now on first start up I'm quite liking it Quote Link to post Share on other sites
