Cherry Posted July 27, 2015 Share Posted July 27, 2015 ABS has just come on, is there a way to tell why. Slammed the brakes on to lock up wheels to test ABS and it didn't kick in Any suggestions Quote Link to post Share on other sites
akyakapotter Posted July 27, 2015 Share Posted July 27, 2015 (edited) im sure i read some where you need to remove the little metal clip at the back of the diganostic port try with it in first ABS diagnostic:Turn on ignitionLink out Tc and E1 in the diagnostic plug.Read the warning light flashes like the ecu.Codes11 Open circuit in solenoid relay12 Short circuit in solenoid relay13 Open circuit in pump motor relay circuit14 Short circuit in pump motor relay circuit21 Open or short circuit in 2 position solenoid of front right wheel22 Open or short circuit in 2 position solenoid of front left wheel23 Open or short circuit in 2 position solenoid of rear right wheel24 Open or short circuit in 2 position solenoid of rear left wheel31 Right front wheel sensor signal malfunction32 Left front wheel sensor signal malfunction33 Right rear wheel sensor signal malfunction34 Left rear wheel sensor signal malfunction41 Abnormally high or low battery voltage51 Actuator pump motor locked or open circuit in pump motorAlways on ABS ecu malfunctionReset by pumping the brake pedal 8 times or more in 3 seconds with the link in or remove ECU-B fuse. Edited July 27, 2015 by akyakapotter Quote Link to post Share on other sites
JDMfreak Posted July 27, 2015 Share Posted July 27, 2015 I actually had to do a abs test on a mates glanza v the other day followed this guide but the abs light didn't flash like the eml light does stayed on constant and got brighter and dimmer. managed to read the code by looking at it with great patience I read you have to put it into diagnostic mode or something Quote Link to post Share on other sites
Cherry Posted July 27, 2015 Author Share Posted July 27, 2015 Cheers guys will give that ago tomorrow Quote Link to post Share on other sites
akyakapotter Posted July 27, 2015 Share Posted July 27, 2015 Got to take the metal pin out I believe Quote Link to post Share on other sites
Cherry Posted July 27, 2015 Author Share Posted July 27, 2015 Metal pin ? Quote Link to post Share on other sites
JDMfreak Posted July 27, 2015 Share Posted July 27, 2015 up in the corner metal pin be careful not to lose it Quote Link to post Share on other sites
