turbominicooper Posted July 27, 2015 Posted July 27, 2015 am i able to do a compression test with just the cylinder head on the block - no cams, sump, oil filter etc? Quote
satyrs Posted July 27, 2015 Posted July 27, 2015 (edited) i gues you cannot do it. it would be possible but maybe not acurate because the valves that let air in arent opening. that way there can be a faulty reading because the lack of air being sucked in. what you can do is a compression leak test. piston in tdc and block kranck. set pressure at x amount and let it rest. so you can see if the valves or rings are still good. good luck Edited July 27, 2015 by satyrs Quote
turbominicooper Posted July 28, 2015 Author Posted July 28, 2015 that's what I thought too. leak down test would be a good idea - cheers Quote
