Start by checking the bulb has not gone in the dials console.
Then check OIL pressure sensor wiring.
Normally light stays on when its messed up but you never know
Edited by 5T4R7ET N/A
Check the wire is plugged into the switch, its located at the lower front of the block, under the slave cylinder near where the gearbox bolts to. Its a single yellow wire which runs up to the thermostat housing and into the rest of the loom.
