Ruddi444 Posted August 7, 2015 Posted August 7, 2015 Anyone got any advice when removing the standard steering wheel apart from disconnecting battery, swapping the wheel for a better condition one and unsure how it comes off? Any help would be great thanks Quote
FrozenJakalope Posted August 7, 2015 Posted August 7, 2015 There's 2 screws on the bottom of the wheel, once those are out you can yank the airbag and get to the boss. Pretty straightforward, you shouldn't have any issues. Like you said, make sure you disconnect the battery first as you don't want the bag to punch you for removing it. Quote
StuDoc 72 Posted August 7, 2015 Posted August 7, 2015 make sure you leave the nut on a few threads when your pulling it off if its tight. Unless you like broken noses in which case just take the nut right off lol. Quote
aleximport25 Posted August 7, 2015 Posted August 7, 2015 i got told that the battery needs disconnecting 20 mins before removing the wheel unsure how true that is but cant hurt surely :-) Quote
StuDoc 72 Posted August 7, 2015 Posted August 7, 2015 (edited) Wouldnt say it needs to be that long but like you say extra safety will never hurt. it's just to allow the capacitors to drain. Edited August 7, 2015 by StuDoc 72 Quote
aleximport25 Posted August 7, 2015 Posted August 7, 2015 sweet il be fitting my new wheel and snap off boss this weekend :-) Quote
5T4R7ET N/A Posted August 7, 2015 Posted August 7, 2015 Just to let you know that the screws that hold the airbag are star shape screws After loosening the screws you might have to pull on the airbag and undo the screws to get airbag off Quote
aleximport25 Posted August 7, 2015 Posted August 7, 2015 Good job a bought a set of star bits a couple of week ago :-) Quote
