glanza ep91 23 Posted August 7, 2015 Posted August 7, 2015 I plan to swap my oem fuel rail to the zisco an10 fuel rail and do I have to swap this part of the oem rail over to the zisco one or can I just leave it out Quote
Ollieh17 Posted August 7, 2015 Posted August 7, 2015 Thats the fuel pressure regulator, you'll have to run a aftermarket one with the zisco fuelRail Quote
glanza ep91 23 Posted August 7, 2015 Author Posted August 7, 2015 What is the an size of the oem fuel pressure regulator Quote
akyakapotter Posted August 7, 2015 Posted August 7, 2015 There is no an on the stock fuel rail it's bolts bud Quote
glanza ep91 23 Posted August 7, 2015 Author Posted August 7, 2015 I mean the an size of the male fitting encircle Quote
Ep82gi Posted August 7, 2015 Posted August 7, 2015 That's not an AN fitting it's a seal with two 10mm bolts either side like Ollieh17 said you will need an after market reg to suit I'm sure if you contact the likes of id workz or TD they can sort you out will all that you need Quote
