markoneswift Posted August 9, 2015 Share Posted August 9, 2015 Hi all, I'm Justin - a UK ex-pat living in sunny New Zealand. I've got a 5E-FHE motor that I'm trying to troubleshoot and I need a bit of advice but info is hard to find about this engine. I figured that most Starlet enthusiasts would be familiar with them, hence my visit here. I recently removed the throttle body (the engine has ACIS, by the way) to try to cure a high idle problem - I assumed the Aux Air Valve was probably jammed and indeed it was. I freed it up, fitted new gaskets etc and refitted the TB. I suspect, however, that coolant is not flowing through the valve due to it being seized for so long but I can't figure out where the coolant hoses connect to. I know one of them is the return to the water pump, but the other (which I assume is the feed) comes from either the back of the head or the thermostat housing but I can't tell which. Can someone please help me identify where this hose connects to? If it goes to the housing I can remove it and clean it out but I don't want to that if the hoses goes to the head instead. Any help would be much appreciated, it's really annoying me now! Thanks heaps :-) Quote Link to post Share on other sites
Stu Posted August 9, 2015 Share Posted August 9, 2015 The feed comes from the thermostat housing and the exit returns to the water pump feed hard line under the inlet. Quote Link to post Share on other sites
