Countryman Posted August 11, 2015 Share Posted August 11, 2015 Does anyone know where the low fuel thermistor is located on a Glanza as my low warning light just stopped working?Any info is appreciated and any pictures showing it would be fantastic. You can what's app me 07846385830ThanksNev Quote Link to post Share on other sites
Jim7 Posted August 11, 2015 Share Posted August 11, 2015 its in the tank on the bottom of the sender unit mate, mines packed in aswell ive got another but that dont work either.i WILL get it working so ill let you know how when i sort it out. Quote Link to post Share on other sites
Countryman Posted August 11, 2015 Author Share Posted August 11, 2015 What does it look like, how do I identify which bit it is?Do you have a pic of the part?Thanks buddy. Quote Link to post Share on other sites
Stu Posted August 11, 2015 Share Posted August 11, 2015 There is a float on an arm and its at at the bottom of the arm. Quote Link to post Share on other sites
Countryman Posted August 11, 2015 Author Share Posted August 11, 2015 Is it the one with the green wire, about 2-3cm long, tapered and got like a pin in the bottom of it? Quote Link to post Share on other sites
Stu Posted August 11, 2015 Share Posted August 11, 2015 Sorry its been a while since Ive worked on one. There's only the pump and the float level in there. Quote Link to post Share on other sites
Jim7 Posted August 11, 2015 Share Posted August 11, 2015 There is a float on an arm and its at at the bottom of the arm. as stu said its at the bottom of the float support bar, there are 5 wires going into the pump 1 live to pump 2 main earth 3 fuel sender 4 fuel sender earth 5 low fuel light. inside the tank the fuel light wire is white it goes to a small metal cylinder with 3 holes in the bottom hope that helps. i have a pic but not sure how to upload on here! (im better with cars than computers!) Quote Link to post Share on other sites
Nafeez2125 Posted August 19, 2016 Share Posted August 19, 2016 Hello guys i am having the same problem. my fuel light is saying on even when my tank is full. ive removed the fuel pump unit and and tried to test the thermistor i put one probe of the multimeter put it on the green wire and the other on the black one from the floater unit and i am getting 20 ohm i took a small container fill it with fuel and submerge the thermistor completely in the fuel an it still read 20 ohm. i recon it should come to at least 1 kilo ohm. so my conclusion is that if i manage to open the canister and remove the thermistor and replace it, this should solve the problem but there is another issue i dont know the the value of the thermistor inside because its faulty. can any one test their working low fuel gauge wire with reference to the ground of the floater and check what is the resistance value when the light is off. And anyone who can shed some light on this please. i know someone who changed it on an AE86 and the value was 1Kohm (AVX 1Kohm NTC thermistor,10s 3.5x3mm (Dia))but i dont know if its the same for glanza. Thanks Quote Link to post Share on other sites
Nafeez2125 Posted September 27, 2016 Share Posted September 27, 2016 Hello Guys, Just a quick update, ive replaced my thermistor and it works perfectly fine just like before. you just needs to be friendly with a soldering iron and be very gentle and patient to get the job done. Quote Link to post Share on other sites
