adzy Posted August 11, 2015 Share Posted August 11, 2015 (edited) Engine management light started coming on occasionally on the way home tonight, the car would lurch and the Rev needle drop away down then up etc. 90% of the time driving it was fine, but I took it easy, also I wasn't on boost when this was happening, maybe 2k revs Looked under the bonnet and my oil breather filter is wet with oil and the dipstick is covered in oil the whole way up. Also a stain around the bottom of the PCV, and Phil did point it out to me on Friday that it looked like it was going.Any help would be appreciated Edited August 13, 2015 by adzy Quote Link to post Share on other sites
adzy Posted August 12, 2015 Author Share Posted August 12, 2015 New PCV ordered, hopefully that's all it is Quote Link to post Share on other sites
adzy Posted August 13, 2015 Author Share Posted August 13, 2015 Anyone any ideas? Quote Link to post Share on other sites
fiddlersport Posted August 13, 2015 Share Posted August 13, 2015 running stock boost ? pcv valve is easy enough to check ! remove, clean it, then just blow through it and see if there is any resistance remove your dipstick while engine running and watch it ! usually when the cylinders aren't holding pressure from combustion then it indicates there is bypass in the cylinder walls simple terms low compression so best do a compression check Quote Link to post Share on other sites
adzy Posted August 13, 2015 Author Share Posted August 13, 2015 Yes stock boost.I removed the PCV valve, when you shake it there isn't a rattle but seems to work when I blow through it. New one will be in tomorro so i'll fit it anyways.Check for vapour I take it with the dipstick out? I'll try that tomorro Quote Link to post Share on other sites
fiddlersport Posted August 13, 2015 Share Posted August 13, 2015 did you do a diagnostic ? any codes ? just check your earth straps on the engine, there are only three, sounds like somethings loose and causing intermittant fault check the plugs in engine bay for loose connection, pull glove box back and have a look there aswell, just to rule out something silly and causing a fault, Iam no expert but these things can be a simple fix and cause alot of problems Good luck http://dub-se7en.toyotagtturbo.com/useful_info/OTHER_PDFS/4EFTE_4EFE_Engine_Diagnotsic_Code.pdf Quote Link to post Share on other sites
adzy Posted August 13, 2015 Author Share Posted August 13, 2015 Yes, bringing up fault code 12 - rpm signal.Where are the 3 earths? Gonna give the leads a clean as well as I was advised to. I'll have a look about tho!Still not sure why the crankcase pressure has got so high to as both seem to have started at the same time.Thanks for the advice! Quote Link to post Share on other sites
