Lads I want to remove my blue e management ecu till I will map it ,can I just un plug it from the loom but leave the e management loom wired in?
After unplugging the aftermarket Ecu will the stock Ecu automatically kick in fulltime then?
Thanks
I've installed a couple of these and have just left all the tables zero'd before taking them to a dyno. From memory you can turn the maps off - its been a while though so can't remember specifically.
  • 3 weeks later...
Yes thats true - bit tricky if you dont have the software.
I believe its still available for download though
blue uses a funny cable too I've have both but if your after one just keep in mind it's not a usb cable
