How 2: Perform A Quadlight Conversion
Quad Lights Conversion on GT guide
As i was doing my Quads conversion, had a Tutorial along.
Unscrew the grill and bumper
Take off the crash bar, easier to work with.
Unscrew the lamp off the brackets.
Cut out all the RED area, inorder for the quads to fit, as they are much bigger than the square lamps.
I use drill and hack saw, easier with air saw or some sort.
The brackets holding the lamps needs to be cut as pictured, but you can always get the brackets for the quads, save you cutting and holds better. as mines not that steady.
After modding the brackets and fitted.
Made my own brackets holding on the lamps, as i only have one at the top, you better to have one at top and one at bottom.
Now drill as the pic shows, so you can screw the lamp in place.
Testing with the grill in:
Wiring the bulbs as so
Here is a Wiring diagram i made:
As its a conversion, you cannot have all beams to come on at the same time, only side lights can be on all times with either main or hi. Cannot have main and hi on together.
After all fitted
Extra info:
High beam - HB4 / 9006
Main beam - HB3 / 9005
you may need to mod new bulbs, as the wings on the bulbs are bigger.
as what i've done to my HID bulbs on the pic.
The left bulb has been cut on the wings, as the right one has big wings on them.
