Jhandy Posted August 20, 2015 Posted August 20, 2015 hey guys ok so having a few problems with the car, fully forged ep82 so went for mapping, turbo was to big blah blah blah went back for mapping on a td05 16g, now it builds boost fine, and gets there fine, but the car will only revto 6500 also with a little misfire, now i have another coil to try, and also some msd ignition stuff that im gonna put there anyway. but what i can work out is if i do a half throttle pull, it will rev higher than 6500. and it has only made 230bhp on a emu. now surely i should be anywhere or above of 300bhp plus. if anyone has any ideas what this can be, would be great, i have checked timingwhen the cams open and closei have even had a engine builder check the cams timing etc im pulling my hair out, and mapping is starting to hurt my pocket jake Quote
fiddlersport Posted August 21, 2015 Posted August 21, 2015 Did the mapper give you any advice ?Engine specs ? Quote
Jhandy Posted August 21, 2015 Author Posted August 21, 2015 He told me to look at the misfire. Which i am gonna be changing for msd ignitionSpecFully forged 4ePeuter rodsRoss pistons Lower compression engine Head port polished. As well as intake maniStandard camsTop mounted zisco kitTd05 16g External wastegate1.6 bar or boostEtcJust dont understand why it wont rev properly Quote
AdamB Posted August 21, 2015 Posted August 21, 2015 Throttle position sensor possibly. First check would be to make sure it's calibrated correctly. Quote
Jhandy Posted August 22, 2015 Author Posted August 22, 2015 I dont know bud. All i do is watch while its being mapped. And gets me more frustrated Quote
turbo-fever Posted August 23, 2015 Posted August 23, 2015 Got they same problem mate changed all the usual bits like plugs dizzy etc and it still does it. Quote
fiddlersport Posted August 23, 2015 Posted August 23, 2015 did the mappers suggest anything ? problems ? worn part ? blah blah blah Quote
Jhandy Posted August 23, 2015 Author Posted August 23, 2015 Pretty sure it was a knackered coil. As it was all broken down. Quote
