Oil pressure decreased when oil cooler installed.
Nope not really. The oil pump is designed to pump oil at a certain pressure with a certain flow. Increasing the distance the oil needs to travel adds resistance before the oil pressure relief valve. You could try to modify the pressure relief valve to give a higher pressure but it could be a loosing battle.
