Hi guys have a celica injector resistor pack and would like some help installing it, so far I know the 4 black wires go to the right side on the injector and the white to all on the left then I'm lost from there
Do those two packs share any wiring? It looks like two different packs to me
Anyway, normally there will be a single 12v feed wire in that's larger diameter and then two or four output wires. So I'd say white is 12v feed and black is 12v to the injectors. What ecu are you using and what impedance injectors are you want to use? You will need to take that into account when working out if those ballasts are the right size.
Ah yeah low impedance units. Ideally you'd want that resistor pack to be at least 4.5-5ohms per channel
I said that above, its the 12v feed to the ballasts.
When using ballasts the wiring goes 12v feed > (ballasts white wire) > ballasts > (ballasts black wire) > injectors 12v side of injectors plug. Other side of injectors plug runs direct to the ecu injector drives.
Edited by Stu
