silkfinish Posted August 25, 2015 Share Posted August 25, 2015 have recently started my project and am not far from finishing but have come across some problemsfirstly I bought a normal starlet that some had had previously converted with a 4efte engine with most or the td04 kit on it. it was rotten so I stripped the car and bought a cat d light panel work glanza s downer car that I would be putting the 4efte engine in to every things in now engine shafts wheels linkages etc the only mistake I made thinking that I wouldn't need the dash loom so I scrapped the car with this still in lolany way I definitely need this rite as I can see that the glanza s dose not have the key reader ring around the key hole what exactly do I need to change in the car for the conversion is there any other looms I need to change that I might have scrapped like the fuel pump loom etc .. ? I need a wiring diagram if possible showing earth points etc what size exhaust/bore size would I need for the td04 setup as I don't think its rite one that previous owner has used ? and if any ones out there has a diagram to plumb in a fuel pressure regulator ? one other thing I have come across when I stripped the other car it didn't have power steering I would like to put this on the car so I took it off the glanza s engine and put it on the 4efte engine before putting the engine back in glanza s shell I cant seem to get the brackets on off the glanza s engine as it hits the oil sandwich plate where oil filter is do you know if the brackets and adjuster for belt tension is the same off n/a engine to the turbo engine or any pics that could point me out getting quite stressed as its near enough finished any help would be much appreciated you guys cheers Quote Link to post Share on other sites
Sportif 4efte Posted November 4, 2015 Share Posted November 4, 2015 Read my conversion how to on my build thread mate doing same as you bud if yu need any help don't hesitate to ask me...http://www.ukstarletowners.com/topic/93289-starlet-sportif-project/#entry1142002 Quote Link to post Share on other sites
