Under the rear site, fuel tank cover. Unplug the harness and 3 screw to be removed, lid comes off.
Than 3 fuel lines to be disconnect.
Than by holding on the fuel lines and take the whole unit out of the tank slowly.
Walbro pump is a bit bigger than the standard one.
Now you have to cut the 2 wires goind to the standard pump, Blue=+ & Black=- . and connect the plug that comes with the kit Red=+ & Black=-.
Put everything back together, because the pump its abit bigger, it will just fit in. and use the old filter and not the new one as the new one is too big and the tank aint got enough space for it.
