Why doesn't fit my GTT steering wheel (OEM) on standard p8
Bought a GTT (OEM) steering wheel sometime ago but it doesn't fit in my standaard P8. It comes to close to the cover of the flasherlight indicators.
Many people said it just should fit like a standaard wheel does, but when i mount it doesn't cause it comes to close to the covering.
I don't have an airbag.
Edited by ries123
The main nut can't be to tight i guess. It should be sure your steeringwheel shouldnt move when driving so you just tighten it untill it doenst want further? Will drop some pics later today.
And about the glanza thing. A lot of people said it should fit (and i saw it also on a belgian starlet 1.5D which is also an P8 model)
Here you see it's to close to the dashboard stuff
Here you see the wheel mounted. It fit's perfect on the column even with the nut on it.
This is the wheel seen from under
I really have no idea why it comes closer to the dashboard as the original one. It fits perfect on the steeringcolumn but after that it's way too close to the dashboard
  • 2 weeks later...
