Gainzy Posted September 24, 2015 Posted September 24, 2015 (edited) After a stock heat shield off the cat with the bolt that holds it on. Edited October 24, 2015 by Gainzy
Gainzy Posted October 16, 2015 Author Posted October 16, 2015 If anyone has the turbo one also with all bolts someone must have the full set lying around
Whitenoize Posted October 16, 2015 Posted October 16, 2015 (edited) I think I've got them mate will check in the garage tomorrow for you I don't have the bolts as they snapped when I took the shield off the cat Edited October 16, 2015 by Whitenoize
Gainzy Posted October 22, 2015 Author Posted October 22, 2015 I think I've got them mate will check in the garage tomorrow for you I don't have the bolts as they snapped when I took the shield off the catIf you just have the stock cat sheild?
Gainzy Posted October 23, 2015 Author Posted October 23, 2015 Also looking for a stock fan connector that comes off the rad fan to connect to my half rad save cutting mine.
Gainzy Posted October 24, 2015 Author Posted October 24, 2015 Center console section to that are in the povety spec glanza's
aleximport25 Posted November 4, 2015 Posted November 4, 2015 Have you tried socks through jdm ep he does single connectors :-) probably a good shout for the heat shield too
