Haltech ecu?
  On 9/25/2015 at 2:31 PM, Ep91 kid said:
Anyone know much about these? Are they plug and play into the standard glanza wiring?.been recommended one by a tuner and I can't seem to find much info on them.
Cheers
Hi mate,
As Socks says no plug and play and loom will need making. If you are going to the trouble of fitting an ECU like that then might as well put brand new wiring in place along with sensors.
I have the PS1000 that I am installing on my Glanza and using there generic 2.5m loom that comes with the ECU and modifying that to work with it.
Either how when it does run it will be awesome :)
All the info you would ever need on them is on the Haltech website and the Haltech technical forum.
Hope this help
