just looking at my options if the auto box ive got turns out to be goosed. found alocal GL for £400, will use running gear out of my GT and have a daily driver until mine is rebuilt next year :)
cheers colin
all the gearboxes have different ratios so there not all the same ive had a 1.0 box in a glanza v and a 1.3 non turbo box in a glanza v both are no good as there ratios are to short the glanza box is better suited to the glanza v box the closest I would call is a cynos gear box ratios are slightly longer only a fraction but is the best box for a swap onto a turbo engine
if you really wanted to push it you could fit a 1.3 6 speed box from a corolla g6 ive seen a glanza turbo running one of these and for long journeys seems to suit them well even at top end the box is screaming and the revs are nice and low
Edited by JDMfreak
