Just ordered the bits to relocate my air filter,
What happens with the vac line that comes off of the efi piper?
Edited by dan106
You can remove the 2 vac lines!
Think they come off the hi/lo boost solenoid iirc
Then just remove the solenoid aswell unless you've still got standard actuator and using the hi/lo boost setting
I have removed the hi/lo boost solenoid and the metal pipes, there's a line from the d/v to the inlet and a line from the efi pipe to a metal hose bolted to the cambelt cover, is it a breather or something?
The bottom one in the pic
A0B744D1-7272-4556-A1F0-B19BF42D958D_zps
mines just vents to air!
Haven't tried removing it yet.
Also where did you get the proper purple hose from ?
I've got the crappy eBay purple stuff which is faded haha
Edited by Cattanach
Find boost junkies on eBay man! It's more expensive but it looks so much better.
Ah right so I can just take the line off and leave it open?
Awesome cheers man!
Yeah mate that's what I've done!, or remove the whole thing if you can find the other bolts
Get a breather filter for the cam cover pipe that came off and just leave the smaller hose off to vent crank as pressure
I don't know what pipe your talking about as the cam covers already got a breather filter on it
And the pipe I meant, isn't that the second vacuum line to the actuator? As I'm still running a standard one with two vac lines
Edited by dan106
Yeah but it only breathes straight back into the efi pipe!
There's nowhere for that vacuum line to go if you have an aftermarket actuator with the one port
