redz11 Posted October 22, 2015 Share Posted October 22, 2015 Only happened the other day.. engine would start then cut out once the accelerator pedal was pushed, the three codes appeared on diagnostics 12,22,42, which I have then checked the ignition HT leads dizzy etc, I cleaned out the dizzy, saw no cracks on it, the rotor arm looked okay also (might be worth replacing them do you think?) WIll be checking all my earths tonight when I get home, the coolant temp sensor is all plumbed in fine so no idea why this is flagging up? maybe new coolant temp sense required? any advice on where to go next? Quote Link to post Share on other sites
redz11 Posted October 25, 2015 Author Share Posted October 25, 2015 Problem was the ECU had gone pop. Quote Link to post Share on other sites
akyakapotter Posted October 25, 2015 Share Posted October 25, 2015 I get speed signal fault. How did you kill the ecu lol Quote Link to post Share on other sites
redz11 Posted October 27, 2015 Author Share Posted October 27, 2015 I get speed signal fault. How did you kill the ecu lol no idea, tried my spare standard ECU in the house (I have a HKS pfc fcon attached, this wasnt the cause of the issue) once this was swapped it started and worked... Quote Link to post Share on other sites
