Dansstarlet1996 Posted October 24, 2015 Share Posted October 24, 2015 im sure this has been covered before but u cant find a solid answer, on a 4EFE engine, would putting a small breather filter on the corner of the block do any harm or good or make no difference?? loads of honda stuff on the web but cant find anything i want to relate to a starlet Thanks Dan Quote Link to post Share on other sites
5e colin Posted October 24, 2015 Share Posted October 24, 2015 just weld an extra fittings to rocker cover it will be cheaper then making a block vent Quote Link to post Share on other sites
Dansstarlet1996 Posted October 24, 2015 Author Share Posted October 24, 2015 what do you mean by a block vent? (sorry if its obvious) http://i67.photobucket.com/albums/h291/keirz/000_0099.jpg thats the bit i was talking about, the little breather on the corner? i have a similar airbox to the one in the picture and wondered if im better doing a similar set up or keeping the hose that connects into the pipe between the airbox and throttle body? Quote Link to post Share on other sites
5e colin Posted October 24, 2015 Share Posted October 24, 2015 thats not a block vent kid thats rocker cover vent i thought you ment block itselve because ours dont have 1 in the ( main ) block thats is perfectly ok to have a vent there but if it starts spitting oil out you will need to get a catch tank also in trafic you might get the od wif of old oil in the cabin Quote Link to post Share on other sites
Dansstarlet1996 Posted October 24, 2015 Author Share Posted October 24, 2015 ah sorry colin im still learning my way around it awesome, just thought id check to see what would happen incase there was something else i needed to do! Quote Link to post Share on other sites
