Hi guys I'm new to td04 setups so just wanted to see if anyone could give me a complete run through of what I will need and how to set it up, I will be running td04L turbo, wepr forward facing manifold setup, apexi cat back exhaust, autobahn intercooler, fcd, fpr and that will be it for the time being just until I can afford piggyback ecu, I just want to know how to setup the likes of oil feed and return and How to setup boost properly what will I need for that? Boost controller and actuator? Bit of a noob with td04 setup so any advice greatly appreciated thanks lads scratching my head with a lot of things 😩😩
  • 2 weeks later...
Dont fit the fcd and run it at 0.7 bar and the standard ecu/fuel setup will fuel it fine until you can afford a proper ecu and map.
