Just fitted a vf10 turbo to my forged ep82, anybody ever used this turbo before? Very similar to td04, just curious to see what boost pressure and power figures anybody has got with this turbo.
I ran one on my 85, but only for a couple of weeks. I only ran it at 0.6bar and never had a dyno figure. Spool was similar to a TD04, maybe slightly more 'laggy'
Never had one side by side a TD04 but i think its bigger. Compressor housing looks bigger and they use a P15 exhaust housing.
Old skool journal bearing turbo just keep wacking the boost up till it stops making power :)
I'm going to run around 1.0 bar, see how it goes, from what I gathered they are slightly smaller than a td04, slightly less power with slightly quicker spool. Hopefully get fueling set up this weekend, then get a run on the dyno see how it performs, should defo see more bhp than the ct9
See i thought they were kinda between a TF035 and a TD04, but i duno 100%
A TD04 is a newer design, so it might make more power that way rather than physical size.
Ideally need the turbos side by side then back to back dyno runs to get any concrete facts about them.
