noticed the car when I rev it is a bit smokey the smoke is a kinda bluey grey colour fine when driving when ya put the foot in seems grand though
would I be right in thinking valve stems want doing
right may order a set of them up have part numbers so will be calling Toyota tomorrow
theres only 93.394 on the engine in the car came outta corolla e11 couldn't be that worn I was half thinking of picking another car up and pull the engine outta it and rebuild this one
haha was written on cam belt cover when belt was done
im gonna order valve stem sills see how it goes ive after putting too much into it now not to do it so might be rebuilt up yet
Age could also be a factor, these engine are now at least 15 years old.
Valve stem seals and piston rings are the most common problem.
If it smoke on idle it could just need pcv valve on rocker cover?
I know these engine are getting on now aswell im gonna chuck a set of valve stem seals in it to eliminate them
I think the smoke on idle is more condensation tbh as it gotten fairly cold these last few weeks pcv valve is working fine
heres a quick video today I took of the car just ticking over clearly you can see the smoke is blue
https://www.youtube.com/watch?feature=player_detailpage&v=sm1kFxsTI-g
Edited by JDMfreak
that's what I was thinking colin but I notice when its cold it does this when it warms up seems grand going to order valve stem seals and get a big can of oil and some engine cleaner for the oil engine flush or something see if I can clean the engine up internally get it to clear any gunk inside the engine out
