JDMfreak Posted October 28, 2015 Share Posted October 28, 2015 noticed the car when I rev it is a bit smokey the smoke is a kinda bluey grey colour fine when driving when ya put the foot in seems grand thoughwould I be right in thinking valve stems want doing Quote Link to post Share on other sites
5e colin Posted October 28, 2015 Share Posted October 28, 2015 yep valvestem seals that also means high milage so worn ish rings quick ring repacement and some guides and she is good for another few miles :) Quote Link to post Share on other sites
JDMfreak Posted October 28, 2015 Author Share Posted October 28, 2015 right may order a set of them up have part numbers so will be calling Toyota tomorrow theres only 93.394 on the engine in the car came outta corolla e11 couldn't be that worn I was half thinking of picking another car up and pull the engine outta it and rebuild this one Quote Link to post Share on other sites
5e colin Posted October 28, 2015 Share Posted October 28, 2015 (edited) must be clocked ?? big habit ere in ireland ha ha Edited October 28, 2015 by 5e colin Quote Link to post Share on other sites
JDMfreak Posted October 28, 2015 Author Share Posted October 28, 2015 haha was written on cam belt cover when belt was done im gonna order valve stem sills see how it goes ive after putting too much into it now not to do it so might be rebuilt up yet Quote Link to post Share on other sites
5T4R7ET N/A Posted October 29, 2015 Share Posted October 29, 2015 Age could also be a factor, these engine are now at least 15 years old. Valve stem seals and piston rings are the most common problem. If it smoke on idle it could just need pcv valve on rocker cover? Quote Link to post Share on other sites
JDMfreak Posted October 29, 2015 Author Share Posted October 29, 2015 I know these engine are getting on now aswell im gonna chuck a set of valve stem seals in it to eliminate them I think the smoke on idle is more condensation tbh as it gotten fairly cold these last few weeks pcv valve is working fine Quote Link to post Share on other sites
JDMfreak Posted October 30, 2015 Author Share Posted October 30, 2015 (edited) heres a quick video today I took of the car just ticking over clearly you can see the smoke is bluehttps://www.youtube.com/watch?feature=player_detailpage&v=sm1kFxsTI-g Edited October 30, 2015 by JDMfreak Quote Link to post Share on other sites
5e colin Posted October 31, 2015 Share Posted October 31, 2015 it could be the Vstem seals the other option is the oil scrapers are gunked up i have seen that on plenty of 4efe fte that makes them smoke to Quote Link to post Share on other sites
JDMfreak Posted October 31, 2015 Author Share Posted October 31, 2015 that's what I was thinking colin but I notice when its cold it does this when it warms up seems grand going to order valve stem seals and get a big can of oil and some engine cleaner for the oil engine flush or something see if I can clean the engine up internally get it to clear any gunk inside the engine out Quote Link to post Share on other sites
5T4R7ET N/A Posted October 31, 2015 Share Posted October 31, 2015 Forte engine flush is good for that.Make sure you read the instructions. Quote Link to post Share on other sites
