Right guys I have the alloy gearbox mount. But I can't get hold of the black bracket for love nor money. Is there anyway to convert the normal bracket to fit the LSD box?
Thanks
you will have to cut it in half and weld a strip in because the bush is wider strength wise i would not trust it !!!
better of making 1 from scratch out of 6mm steel plate a 50cm length wil do the job cost around 3£
Did you give the guy in the parts dept in Toyota the correct VIN for an OEM LSD car?
Yeah I gave him all the correct details, it gives you an options on the diagram for the LSD mount.either way it's discontinued :(
