I broke it..
My car survived a dozen laps before ceasing to cooperate.
Something let go at around 7000 rpm in third and I now have the following compression results
150
150
0
0
Gasket? Bent valve(s)?
Taking the head off on Saturday to find out for sure.
I'm likely to blame, perhaps I made a mistake assembling. Perhaps the block that I checked as being flat isn't flat?
Engine stills runs, albeit on two cylinders. Cams appear to be in one piece, there isn't any blow by to speak of either.
Place your bets now..
What head bolts did you use? Did you re-check the torque after like 50 miles?
no need for that toyota bolts are stretch bolts dont need retorque
unless you have those uprated bolts ??
Edited by 5e colin
Did you re-use the headbolts? Or are they new ARP's?
I just checked the installation instructions for 4E/5E head bolts, it doesn't mention anything about re-checking the torque so I might have got confused with something else there, my apologies.
Edited by AdamB
  • 3 weeks later...
Got the head off today..
Revealing a rather broken head gasket between 3 and 4.
What was expected really, but there is some damage to the piston number 4, and some odd pitting on the cylinder wall, hard to photograph. Especially hard with my iPhone, I can't find my camera anywhere!!
tUGldjIl.jpg?1
The damage to the piston wasn't there before, can't be certain if the pitting on the cylinder wall was there or not. I guess the big question is does this mean the bottom end needs repair as well?
Head looks damage free to me, again apologies for the awful photos.
What do we reckon?
I'd have thought it was the piece of gasket rattling around rather than the tune. Rest of the pistons are perfect
