typh183 Posted November 27, 2015 Posted November 27, 2015 trying to find the ecu in my starlet gt turbo, i know its in the center console somewhere but not sure which parts to remove etc, is there a guide anywhere? I've had a look around cant seem to find anything other than people saying its near the gearbox... Quote
patman Posted November 27, 2015 Posted November 27, 2015 If you look to the left of the foot rest next to the clutch your see the ecu there, so it's like saying its behind the ashtray right in the middle there hope this makes sense Quote
typh183 Posted November 27, 2015 Author Posted November 27, 2015 If you look to the left of the foot rest next to the clutch your see the ecu there, so it's like saying its behind the ashtray right in the middle there hope this makes sense i looked from near the drivers footwell i can just see it, im just unsure what i need to remove to get to it properly. il just start removing parts of the interior tomorrow lol Quote
adzy Posted November 28, 2015 Posted November 28, 2015 Behind the glovebox, not gearbox lolAh whoops didn't read it was a gt Quote
Sheehy StarletGT Posted November 28, 2015 Posted November 28, 2015 It is in a small ecu holder left of the clutch pedal and will have a stuck on black film on top to cover it (if standard) no major bolts to remove only afew 10mm bolts. It comes out easy enough and there will be two plugs connected into it (3 plugs in some late 95 mark 3 models) hope this helps Quote
