Headgasket needs doing on the Glanza. Currently runs 1bar td04 on standard engine.
Will probably do some headwork and get bigger injectors and maybe go to 1.2bar
What sort of headgasket should I get, what does anyone recommend?
Thanks
Cruise/Zep gasket, depending on if the head has been skimmed before or how much gets taken off then 1.2mm-1.4mm will suffice.
As far as I know this will be the first time the head has been off so everything should be as standard.
Whats standard thickness gasket and what advantage is there to changing that, I know it changes compression but how does that affect things like lag or just how the engine performs?
Edited by Galen
Standard gasket is 1mm compressed I think. You'll get a bit more lag with thicker gasket, but if you plan on increasing boost on OEM motor it'll make it that little bit more reliable.
