Lynch Posted December 2, 2015 Posted December 2, 2015 Hows it going lads, I've got a 97 glanza v. The abs light is staying on. I flashed the codes and it came up with faults for the 4 abs sensors signal malfunction and abs voltage abnormally high/low. I tried another abs relay and it made no difference.I was just wondering if there is any common issues with them, before I go and start buying parts for it. Also, I would prefer to fix the abs, and not to remove it.Thanks guys. Quote
Calum122 Posted December 21, 2015 Posted December 21, 2015 Just out of interest, I don't know the answer, does the ABS still work? Quote
5e colin Posted December 21, 2015 Posted December 21, 2015 try cleaning the sensor tip and abs ring they might be full of gunk and the sensor cant read try that first also check if the wire aint cut/cracked you can also ohm the wire to see if its still in spec like this in the link have a look >https://www.youtube.com/watch?v=7eCJa7JZzfg Quote
