What air filters have people gone for? I want to get a cone filter but I don't know which one to go for and what size any info would be great.
Thanks. Phil.
Apexi cone filters are the best in my opinion followed by k&n
I shall have to have a look. I don't suppose you have any dimensions do you? I.e size of piping needed.
Thanks. Phil.
What is it for turbo or n/a application?
N/a when I bought it it had one on it but the pipe was short so was wedge under the distribution cap. Want a new one so that it runs better.
I think Apexi ones usually about 53-55mm off the top of my head
Ok thanks will probably have a measure up to check before I get anything.
Get it away or shielded from any heat source.
The bmc enclosed ones are good as they have an enclosed casing and an opening that can be ducted to a source of cold air. Only thing is they wont make as much noise
They're generally more expensive as well aren't they. And who doesn't like more noise :D
