Hey all, right so I've started stripping down my back calipers to Change all the seals I've removed the piston and boot but can't work out how to get the rest of the assembly out? I've got a basic guide and it mentions using a sst tool ?
Thanks Alex.
Theres a circlip down the bottom of the piston cavity that needs removing to get them bits out. once that stuffs out the arm/rod that comes in from the outside where the handbrake lever is should come out.
Get a decent set of circlip pliers for putting it back together. The set I have, have quite worn tips and it proved a bloody nightmare assembling it again!
John
