Reeceep91 Posted December 24, 2015 Share Posted December 24, 2015 So the car started to loose power and struggled to idle when I stopped the car it wouldn't start. I Changed the spark plugs checked the whole ignition system and its fine getting a good spark. Checked the whole fueling system getting good pressure changed the rail and injectors to be sure and still the car is very hard to start and when it does it's only Ideling at around 100 rpm. Any ideas?? Quote Link to post Share on other sites
aleximport25 Posted December 24, 2015 Share Posted December 24, 2015 Have you done a compression check buddy ? Quote Link to post Share on other sites
H_D Posted December 25, 2015 Share Posted December 25, 2015 (edited) Tps probably needs adjusting. Also check the icv and try adjusting the idle screw Edited December 25, 2015 by H_D Quote Link to post Share on other sites
Reeceep91 Posted December 25, 2015 Author Share Posted December 25, 2015 No haven't got round to doing a compression test yet. Quote Link to post Share on other sites
