Vturbo Posted December 26, 2015 Posted December 26, 2015 Sorry if this has been asked before but I couldn't find anything, has anyone got pics of where the vac and water pipes go on the inlet? As I want to be sure when the new engine goes in. Thanks! Quote
patman Posted December 26, 2015 Posted December 26, 2015 (edited) http://www.toyotagtturbo.com/forums/showthread.php?67023-Throttle-Body-Pipes-* http://www.toyotagtturbo.com/forums/showthread.php?80644-what-pipes-are-these&highlight=inlet+pipes Edited December 26, 2015 by patman Quote
patman Posted December 26, 2015 Posted December 26, 2015 Please make sure you double even triple check the lines are right when fitted mate you definitely don't want coolant going down the cylinders Quote
Vturbo Posted December 26, 2015 Author Posted December 26, 2015 Please make sure you double even triple check the lines are right when fitted mate you definitely don't want coolant going down the cylindersWill do! Definitely don't want that on a fresh build! Quote
