I want to relocate the battary to the boot anyone done it? Do I have to run a new cable from the starter and the fuse box and where will I get a fuse to put on the power cable in the boot ( I have to as won't pass the nct/mot. Any ideas lads to do it the right way. I will be using the cables from a Mercedes that had a battery in the boot from factory.
Run the new cables from the battery to the starter and fuse box. Put the extra fuse as close the battery as you can and use big enough fuse as the starter will draw high current.
