Recently bought wepr kit and a turbosmart wastegate now I'm led to believe that the wastegate has two springs in it, is it possible to remove one Spring so I can just run the 7 psi spring and get the mani and few bits on the car until I'm going to get it mapped? Also where does the second port on the wastegate have to be ran to with vacuum hose? First to a boost pressure source and second to where?
Some wastegates have smaller helper types springs inside the main spring, so remove it and see what boost it runs at.
Bottom port goes to compressor housing, top port just vents to atmosphere if your just running spring pressure.
Top port is used when your using a boost controller
Bought it second hand and on the box off it says 14psi so I'm presuming there's a 7 psi inner and 7psi outer ring so would I be better off running the smaller spring or bigger?
Thanks lads :)
There was a big one and a small one the big one was 105mm in length and the small one was 60mm in length not sure which one to go with as the chart is confusing on the turbosmart site
