So, today I washed my engine bay and after that I started the car, everything was fine, then it reached temperature and the noise changed, now, when I rev it, from idle to 2k rpm it chokes and shakes, it's fine at higher revs though... could it be my leads/spark plugs? or is it just because I'm low on fuel on an incline?
Here's a video so you can check for yourself:
>https://www.youtube.com/watch?v=8Qi2mr3B5XY
Edited by EP70-PT
Most likely water in the ignition system eg down the plug holes.
Just a matter of letting it dry then? I just got the car, I'll eventually change the plugs and the leads
Yeah I think that is the reason, I got zapped when I touched around the Dizzy, it was dark, don't know exactly where but it wasn't the battery
