decdd19 Posted January 3, 2016 Posted January 3, 2016 see which ye know lads the grey plug there are two both in each wing on the same loom as indicator bulb . the one on the drivers side has a black plug to 4 pin grey plug comes down behind the drivers headlight nearly down to the bottom of the intercooler runs down beside my short route pipe these 3 run down the centre front frame bar clip onto the bonnet bracket bar Quote
Socks Posted January 4, 2016 Posted January 4, 2016 Black witrh yellow inserts are HORNs. They have 2 horns... Quote
Aamir Posted January 4, 2016 Posted January 4, 2016 2nd Photo is for the fog lights isn't it? 3rd for the Aircon? Aamir Quote
aleximport25 Posted January 4, 2016 Posted January 4, 2016 2nd Photo is for the fog lights isn't it? 3rd for the Aircon? AamirX2 :-) Quote
aleximport25 Posted January 4, 2016 Posted January 4, 2016 I think the 2nd to last is for the ac fan Quote
Flaminsam Posted January 5, 2016 Posted January 5, 2016 I think the 2nd to last is for the ac fanSecond to last and the last pic are for the ac fan. The other sensor with that plug is outside air temp to do with the air con/climate control. As socks says the ones with the yellow inserts are the horns (green with red trace I believe) and the square plug (4 wire) would have gone to the air con compressor. Quote
decdd19 Posted January 5, 2016 Author Posted January 5, 2016 brilliant thanks lads... any problems be caused if i cut off the aircon plugs? Quote
Flaminsam Posted January 5, 2016 Posted January 5, 2016 If one of the sensors is removed I believe the radiator fan is left on permanently (it was on my gt) had to link two wires to stop the fan so it only ran on the coolant fan switch instead. Besides that no problems removing the wiring. Quote
