ChrisLeeBoost Posted January 9, 2016 Posted January 9, 2016 Well lads what are all youse doing to get car through nct/mot with td04 setups? Was thinking of making up an adapter plate to bolt the standard cat to td04 manifold but it'll be gasketless then and won't be a good seal? Would it be worth the hassle getting it bolted on or should I just throw standard stuff back on for test? Dreading the thoughts of testing it so much Quote
.ep82. Posted January 10, 2016 Posted January 10, 2016 I put a cat in with the td04 and still failed ,ended up just throwing the ct9 back in Quote
Johnboy GT Posted January 10, 2016 Posted January 10, 2016 I got a flanges welded on my midsection so I can bolt in a cat or a decat pipe. John Quote
5e colin Posted January 10, 2016 Posted January 10, 2016 (edited) i did this it passed emissions test ere in ireland at the nct so it works no aftermarket beats the stock cat !!! so you get the idea you can do this with toyosports / speedvision manifolds to , you will have to use the 2 gaskets mate for the cat adaptor plate tdo4 and ct9 i used exhaust paste on them to dont mind the rattling sound it was the topmount bracket being loose and vibrating >https://www.youtube.com/watch?v=dSECd44R78k Edited January 10, 2016 by 5e colin Quote
ChrisLeeBoost Posted January 10, 2016 Author Posted January 10, 2016 Mine has a wepr kit on it at the moment but I could throw my old toyosports kit on no problem just need to make up an adapter plate out of say quarter inch steel?? What way did you cut out the shape of the ct9 cat on the adapter?? Quote
5e colin Posted January 10, 2016 Posted January 10, 2016 i used 8mm or 6mm plate to attach the cat i think i still have a adaptor plate for the toyo here somewhere cut out with pillar drill and a taaaaaaaaat of filing ha ha Quote
ChrisLeeBoost Posted January 10, 2016 Author Posted January 10, 2016 Any pics of it you can send me Colin? I'll just copy you ;) Quote
5e colin Posted January 10, 2016 Posted January 10, 2016 will have a look there 2moro if i forget remind me Quote
